Disappearing dime puzzle
Author: Rea Gibson
Published: February March 2003
Place a dime in the hole of the coin block. When you push the coin block into the wooden pocket, the dime disappears.
Coin Block & Wooden Pocket
Or, a variation on this trick is to have a penny turn into a dime. With a little practice, you’ll soon be turning pennies into dimes and dimes into thin air!
• Make up all the pieces as shown.
• Glue the side and end spacers to the top.
• Adjust the slider so that the two holes match up exactly with the hole in the top, as it moves back and forth.
• Sand the slider so that it moves freely when the bottom is glued into place. Be careful when gluing so that the slider remains free.
• Drill a hole through the centre of both end spacers so that the nail in the wooden pocket can push the slider back and forth.
• Before gluing up the pocket, put a nail (with the head removed) in the centre of the end space. Let the nail protrude 1 ⅜”.
(Magician’s note: make sure you hold your hands, and the slider, in such a way that your audience doesn’t see the holes in the ends of the slider.)
