Home Improvement
How to replace a broken floor tile
If a tile breaks it will need to be repaired.... Read more
HomeInOn – vanities and sinks
Installing a new vanity, sink and faucet can transform your... Read more
HomeInOn – Hygrometers for home or shop
The most effective way to know when the moisture level... Read more
HomeInOn – Humidifiers in your home or workshop
You can’t control the weather but you can control the... Read more
Caulking and sealants
Use the right product to keep water, moisture, air and... Read more
HomeInOn – 4 ways to keep your house cool
Summers are getting hotter right across Canada. We list a... Read more
Install kitchen pullout shelves
It’s easier than you’d think to install functional, space-saving pullout... Read more
Installing crown moulding – part two
Sloped ceilings are quite popular in houses – adding crown... Read more
Working Out of Your Home? Work Smart
Maintain your productivity and efficiency when working at home by... Read more
Install a plywood floor
When you need a cost-effective flooring solution but still want... Read more
Install a sun tunnel
Installing a sun tunnel to bring natural light into an... Read more
Awesome gifts for the dedicated DIYer in your home
Choosing the right gift isn’t always easy. Here are gift... Read more
Installing a Drop-In Kitchen Sink
Replacing a top mount kitchen sink isn’t overly complicated. Preparation... Read more
HomeInOn – How to Choose a Kitchen Sink That Shines
We help you make the right choice when the time... Read more
Cabinet installation – part 5
This is the final installment in the series of articles... Read more
HomeInOn – Windows
Whether installing new or replacing old, we provide the basic... Read more
How to Replace an Old Window
Upgrading an old window can be a great way to... Read more
How to install a beam to replace a load-bearing wall
With a little planning and research someone with reasonable carpentry... Read more
HomeInOn – Easy Dust Management for Healthy Homes
Carpeting can be expensive to install or replace. Keeping the... Read more
Build a classic bathroom vanity
The clean lines on this vanity look great, and it... Read more
HomeInOn – Window Film
Increase indoor comfort and lower your energy... Read more
HomeInOn – Dehumidifiers
Excessive humidity can be a real problem for your home... Read more
How to measure for and cut custom exterior stair stringers
With a logical approach, and a little know-how, creating custom... Read more
9 things to look for when buying or renovating
Here are a few of the most critical points to... Read more
HomeInOn – LED kitchen cabinet lighting
LED lights are an easy-to-install, cost-effective way to improve the... Read more
Flood Proof Your Home
While you can’t entirely protect yourself from Mother Nature’s wrath,... Read more
Docked and Loaded
A how-to guide to building the ultimate dock for your... Read more
HomeInOn – ductless heat pumps
Here's a way to add a heating and cooling system... Read more
HomeInOn – Entry doors
The front entry door is not just about a fabulous... Read more
Create your own great outdoors
Expand your useable living space into the backyard with these... Read more
HomeInOn – kitchen cabinet makeovers on a budget
When it comes to giving your kitchen a bright new... Read more
Copper Countertop
Using copper as a countertop surface will leave you with... Read more
Build an interior door
Building a set of doors is a great way to... Read more
HomeInOn – Tankless water heaters
On-demand hot water systems save space, save energy, and save... Read more
HomeInOn – Insulation Options
Optimizing the energy efficiency of your home includes proper... Read more
Winterize your home
DIY tips to make your house less drafty this... Read more
HomeInOn – 6 roofing material options
Is your roof looking its age? Is there moisture seeping... Read more
Make a splash
A step-by-step guide on how to install a tile backsplash... Read more
HomeInOn – shop and garage floor coverings
Concrete and plywood are common options for shop floors, but... Read more
HomeInOn – Siding
There are a lot of great choices when it comes... Read more
WINDOW WISE: A Guide to Planning, Framing and Installing a New Window
With only basic tools it’s possible to add a window... Read more
HomeInOn – Flooring
Floors can take quite a beating, especially in high traffic... Read more
Levelling a Problem Floor
From carpenters to floor installers to homeowners, nobody likes an... Read more
HomeInOn – countertops
The kitchen is the heart of the home. It’s a... Read more
Introduction to Interior Trimwork
Learn about the terms, tools, materials, and equipment necessary for... Read more
Make Your Own Baseboard
If you’re looking for a unique look or a specific... Read more
Board & Batten Wood Siding
Vertical wood siding is a time-proven, versatile, environmentally friendly, locally... Read more
Heritage Homes
If your home has been designated as a heritage home,... Read more
How to install beadboard
Installing beadboard is a great way to transform and update... Read more
Hidden Hinged Spice Rack
Home Improvement: This under-cabinet spice storage rack will work wonders... Read more
Giving Our Past a Future: Renovating Corbels
Sometimes it’s the smaller details that are the most important.... Read more
How to Build Solid Wood Countertops
Solid wood counters have been around since the beginning of... Read more
Accessible Living
From minor additions to major overhauls, changes to a home... Read more
Wood Sidewall Shingles – Mastering the Basics
Wood shingles add style, texture and durability to any sidewall,... Read more
Common Cents: Renovation Financing
Most of us enjoy making small improvements to our own... Read more
Materials for the Great Outdoors
Next time you are planning a project for the outdoors,... Read more
Ramping up for access
Stairs pose an insurmountable barrier to many Canadians, but access... Read more
Build an arched pergola
Adding a pergola to your deck is a great way... Read more
Interior door installation
Although it seems simple, hanging an interior door can be... Read more
Restoring a Historic Porch with Custom Details
Attention to heritage details is the key to restoring this... Read more
Under the stairs storage
Six Creative Ways to Make the Best Use of Space under... Read more
Installing Floating Floors
How a finished floor turns out is mainly in the... Read more
Build it Once
11 Tips for a Stronger, Longer Lasting... Read more
Crafting a Window Seat
Use some time-saving tricks to make this window seat, then... Read more
Kitchen Cabinet Facelift
Breathing new life into a tired, outdated kitchen on a... Read more
Trim frames
A woodworker’s unique approach to making and installing door and... Read more
Installing crown moulding – part three: curved walls
Placing crown moulding on curved walls can seem like an... Read more
Refinishing wood floors
Make your wood floors look like new with these four... Read more
Installing crown moulding – part one
Of all the trim work in a house, there is... Read more
Mill-it-Yourself Handrail
Simple tools and techniques for routing this traditional architectural feature... Read more
Click Floor Tricks
Take a look at these six woodworkers' secrets for a... Read more
Window shutters
If you’re looking for a window treatment that adds style,... Read more
Entrance Doors
Doors are one of the most immediate and welcoming features... Read more
Door Surrounds
When I bought my first house I knew there was... Read more
Entrance gates
A well designed and constructed entrance gate can add appeal... Read more
Hardwood Flooring
Walk into any room and chances are that the first... Read more
Fireplace Surrounds
Enhance the look of your living room with a spectacular... Read more
Classic Wainscoting
Add charm, character and visual appeal to any room with... Read more
Easy kitchen countertops
Invariably, if you update your kitchen cabinets you’ll think about... Read more
Refacing Doors & Drawers
Don't replace all your kitchen cabinets - save money and... Read more
Installing crown moulding and baseboards
Crown moulding with matching baseboard can add a distinctive look... Read more
Wood paneled ceiling
Incorporate wood paneling into your ceiling for a spectacular... Read more
Venetian blinds – how to repair
Repairing venetian blinds is not as complicated as you... Read more
Special cabinets and countertops – part 4
This article is the fourth in a series of five... Read more
Building base cabinets – part 3
This article is the third in a series of five... Read more
Building upper cabinets – part 2
This article explores various cabinet styles, and related issues to... Read more
Building kitchen cabinets – part 1
This article details some of the issues involved in design,... Read more
