Lynx concave and convex scraper sets
Scrapers are exceptionally useful in the shop; they’re a lot quicker to use than sandpaper, and, when properly polished and burnished, they produce a silky smooth surface ready for finishing.
These specialty scrapers are sold under the Lynx brand, which were made by the Garlick Saw Company (founded 1858) in Sheffield, England, until acquired by Thomas Flinn & Company in 1999. Thomas Flinn, who have been making saws since 1923, are the last UK company making traditional saws primarily by hand, so they should know a thing or two about working steel.
ManufacturerThomas Flinn & Co
Set includes: Concave and convex
Price: $21 for each set of 2 or $37.90 for all 4
Made in: England
SourceLeevalley.com
Features:
  • 1/32″ thick (average 3-1/4″ diameter)
  • High quality tempered steel
  • 5 profiles on each scraper
  • Concave scraper profiles: 1/4″, 3/8″, 1/2″, 5/8″, 3/4″, 7/8″, 1″, 1-1/8″, 1- 1/4″, 1-1/2″
  • Convex scraper profiles: 1/4″, 3/8″, 1/2″, 5/8″, 3/4″, 7/8″, 1″, 1-1/8″, 1- 1/4″, 1-1/2″
Convex set
The Lynx scrapers come in two sets of two scrapers – a concave set for working beads, dowels and various concave mouldings, and a convex set for working flutes and convex shaped moulding.
Each scraper has five sizes – 1/4″, 3/8″, 1/2″, 5/8″ and 3/4″ on one scraper and 7/8″, 1″, 1-1/8″, 1-1/4″ and 1-1/2″ on the other scraper. These sizes cover a pretty wide range of the most common sizes used in woodworking. The sizes are exactly matched – the 1″ convex for example, fits precisely with the 1″ concave – ideal if you’re fastidious about ensuring that same size moulding matches perfectly.
Concave set
The scrapers are made of tempered steel and are nice and thick – a full 1/32″ – so they won’t flex in use. While you could use the scrapers as they are, they’ll really benefit from a quick polishing (honing) and burnishing. The process is quite easy.
For polishing I wrap P1500 grit wet/dry silicon carbide sandpaper around dowels to fit the scraper sizes. The silicon carbide cuts very quickly, so polishing the edges takes only a few minutes. To burnish the scrapers I use the Veritas Round Burnisher; it’s easy to use and has a 5/16″ diameter A2 tool steel rod. If you need more detail check out Bill Perry’s article on using a scraper – it’s on card scrapers but the technique is basically the same for these Lynx scrapers.
For the price these Lynx scrapers are exceptional value. They’re particularly handy if you make chairs or stools and are super when it comes to cleaning up mouldings. Get them – use them!
