Photos by CWHI
Spektra CNC Router Bits
Amana’s Spektra solid carbide router bits feature a micro-thin nanocomposite ceramic coating that enables the tool’s cutting edge to retain crucial sharpness and lubricity, providing up to 2.5 times longer service life. The coating prevents high heat build-up and oxidation, which is detrimental to cutting performance. There are a range of cost effective Spektra bits to choose from for both CNC and router applications. They include 2- and 3-flute plunge bits for plastic, wood and composite materials; v-groove carving/engraving bits; compression bits; and ball nose bits.
Tormek T-8 Sharpening System
The most advanced water cooled sharpening system available is Swedish made and allows you to sharpen your tools to the finest edge, without removing more steel than necessary. The Tormek T-8 is built for continuous duty and has a unique and efficient drive system that manages to hold a constant speed, even under full load. Your tool’s edge is continuously cooled by the water, which means there’s no risk it gets overheated. Supplied with the machine is a number of accessories, including the unbeatable Square Edge Jig SE-77. The most versatile sharpening system you can own.
Prodigy Desktop CNC
The Prodigy 1212P is a high performance, easy-to-use CNC that excels for use in Makerspace, educational, and craft/hobby applications, is designed for continuous duty at full power in all speed ranges, and is extremely safe for users of all ages. The Prodigy features a heavy duty frame and gantry cast in thick aluminum for rigidity and accuracy. It has a sliding anodized 450mm x 440mm aluminum table with a 300mm x 300mm x 100mm machining area rather than a moving gantry for the “Y” axis, and comes complete with a 300 watt 20,000 RPM variable speed motor with 4mm, 1/8″ and 1/4″ ER11 collet chucks.
Canada’s Sandpaper Specialist
Sandpaper is one of the most commonly used consumables in the workshop, and the Sandpaper Family (formerly Royce Sales) has been the premier source for quality abrasive products for over 25 years. They carry premium sheets and discs in both hook and loop and PSA backings, along with standard size and custom belts, rolls, and spindle drum sleeves. Their premium discs and sheets are made of open coat aluminum oxide with a top coating to reduce loading. The Sandpaper Family carries an extensive grit selection and pricing is very competitive, providing you with fantastic dollar value.
PureBond Hardwood Plywood
Canadian-made PureBond plywood is the #1 choice among woodworking professionals. It features timeless face veneers in Red Oak and Maple with smooth inner core layers, delivering maximum potential for beautiful finishing results. There is also a sanded Aspen panel that’s perfect for projects that you will end up painting. PureBond plywood uses soy-based adhesive rather than urea formaldehyde, making it a safer product for you and your clients. PureBond is even more water resistant than UF panels. What makes PureBond even more special is that it’s cost competitive with the standard urea formaldehyde construction that you’ll find in most decorative veneer-core hardwood plywood on the market today, and it’s in-stock at Home Depot locations across Canada. Better for you, your customers, and it’s better for the environment.
Grizzly 15″ Heavy-Duty Planer
The G0815 planer can improve the functionality of your shop without sacrificing precious floor space, while still having the power you need to tackle large projects or do production work. It features a powerful 3HP motor and 5,000 RPM cutterhead speed. The headstock sits atop a four-column support with easy hand wheel height adjustment and column locks. The G0815 offers 16 and 30 FPM feed rates to ensure the smooth finish you need on various wood types. The three HSS knives are easy to install and deliver smooth, clean cuts on all wood surfaces.
Grizzly Tenoning Jig
The fully adjustable T30491 Tenoning Jig fits left and right tilting table saws with 3/8″ x 3/4″ miter gauge slots while handling stock up to 3-1/4″ thick. It has an adjustable guide bar for removing any loose play for precise results and two large grip handles for smooth control. The bevel angle is adjustable from 90° to 75°, and the backstop is adjustable from 90° to 45°. The multi-position control levers and extra large clamping hand wheel ensure accurate and repeatable results. Additional assembly required for left tilting saws.
14 in1 All Purpose Multidriver
The new Benchmark 1058-560 ratcheting screwdriver is not actually a ratchet at all. Its silent, click-less, extra smooth roller bearing ratcheting action is patented and unique. This multi-driver has 7 high quality S2 double ended bits and a stainless steel magnetic bit holder that doubles as a 1/4″ nutdriver. The high torque softgrip handle is comfortable to use and non-slip. 6 bits store in the handle, the 7th in the bit holder.
Gorilla Gripper Panel Carrier
The 1010-503 Gorilla Gripper is a unique construction hand tool that allows one person to carry heavy sheet goods such as plywood, drywall, particleboard, MDF, Melamine and sheet metal, from the top, with one hand. By not carrying sheet stock overhead you get an unobstructed view of where you’re walking without the need of ducking down to get through doorways. It provides less strain and greatly reduces the risk of injury to your back, neck, shoulders, arms and hands.
Mini-Mite 3 PLATINUM™ Model
The Mini-Mite 3 PLATINUM™ model is a real favorite with cabinet makers and professionals. This award winning model is equipped with a Heat Dissipation Box that removes any heat build-up from the turbine case, and Noise Reduction Covers that reduce noise for a quieter overall spray experience. The 3-stage turbine, which develops approximately 6.5 psi, is powerful, portable, and perfect for all fine-finishing. Additional power allows the user to apply heavier coatings and thicker viscosity finishes faster and with less time spent on preparation of materials. The system is easy to operate and maintain. Included with the turbine are a professional grade non-bleed spray gun, 25 foot Hi-Flex hose, #4 Ford viscosity cup, wench, and cleaning brush. The Mini-Mite 3 comes with a 2-year warranty on parts and labour.
10 Gallon Ultra-Quiet Air Compressor
The KC-10020SQ packs a lot of power into a compact compressor. It features a durable 3HP, 14 Amp motor with a twin cylinder oil-free pump for faster air recovery, a 10 gallon air tank, and a low 75 decibel noise level. The pump is rated for 3,000 hours of service. Air delivery is 5.6 CFM at 40 PSI and 4.4 CFM at 90 PSI. There are two 1/4″ universal quick connect couplers so you can connect up to two air tools, and 6-3/4″ wheels for portability.
Oscillating Spindle Sander
The KC-701C is the ideal benchtop machine for sanding contours, arcs, curves, and other irregular shapes. A simultaneous rotating and oscillating effect ensures exceptional finishing results. It has a powerful 1/2HP motor that delivers a spindle speed of 2,000 RPM and a 5/8″ oscillating stroke. It features a precision ground heavy-duty cast-iron table and convenient on-board drum and table insert storage. The sander comes with a 1/2″ spindle, 3/4″, 1″, 1-1/2″, 2″, and 3″ drums, 6 80-grit sanding sleeves, 6 table inserts, washers and adjustment wrench.
Laguna REVO 12|16 Lathe
The new REVO 12|16 is the most robust MIDI lathe on the market. Equipped with a 1HP motor, it features a Pulse Width Modulation inverter that allows for consistent and powerful torque through all speeds with no dropping of speed under load. You get 15-1/2″ between centers, a 12-1/2″ swing over the bed, and 9-1/2″ over the banjo. There are 3 speed ranges from 50 to 3,500 RPM. The REVO 12|16 includes a full function spindle lock, reverse function, self ejecting center removal, and so much more. There are a wide range of accessories to choose from including a mobility kit, halogen light, adjustable stand, and expansion set. Note: Photo shows the REVO 12|16 with all accessories installed.
SuperMax 16-32 Drum Sander
The 16-32 drum sander is the newest member of SuperMax Tools family that was designed with new features to improve productivity. The newly patented Quick Adjustment Lever creates a faster way to change the drum height and allows it to move from 0 to 3 inches with one pull of a lever versus multiple revolutions of the hand wheel. Another significant change from previous models of the 16-32 is the rear placement of the Gear Motor. This allows for stock to be pulled through, rather than pushed, to improve conveyor belt tracking.
Laguna 18|BX 18″ Bandsaw
The 18|BX Bandsaw follows in the traditions of high-performance and reliability established by the widely-used Laguna Tools 14|12 and 14|bx models. You get a full 16″ resaw capacity. The 18|BX is built around a 3HP, 220V motor and 145” (368 cm) blade for consistent results, cut-after-cut, regardless of the material. It features magnetic start, disc-brake with micro switch, magnetic blade tension guide, work gear and pinion upper guide, and 10-point ceramic guides. The 20″ by 26″ cast iron table tilts from -6° to +45°. An optional mobility kit and pro light system are also available.
Mirka Dust Extractor
The Mirka DE-1230-PC professional dust extractor has a high performance 1,200 watt motor and turbine, that creates a 250 mbar vacuum and 4,500 liter per minute of air flow. At only 60 decibels this is one of the quietest extractors on the market. It includes 3 layers of dust protection and filtration including certified HEPA filter. It has a flat top with space for storage and large wheels for better manoeuvrability, along with a push-clean function and integrated hose and cable storage for more comfortable transportation. A fleece dust bag is also included. A Mirka antistatic hose (not included) is recommended.
Mirka DEOS DELTA Corner Sander
The Mirka 663CV direct electric orbital corner sander provides a compact design and very low profile, ensuring high manoeuvrability and excellent balance, making it ideal for sanding corners, profiles, and both vertical and hard-to-reach areas. A 250 watt brushless motor delivers variable speeds from 5,000 to 10,000 RPM, while a 100 x 152 x 152mm multi-hole pad provides efficient dust extraction. Its 3mm orbit delivers effective and fast stock removal. Combined with a comfortable and ergonomic grip, this means that you can sand for long periods without fatigue. The 663CV has an integrated vibration sensor and Bluetooth low energy technology.
Moray – Ready2Laser Desktop Laser System
The Made in USA Ready2Laser is an affordable desktop laser system with a powerful 7 watt solid state laser diode. Ready2Laser includes design software that allows users to create files from almost any image. Users can also import images from other software and can raster, trace, and perform light cutting on balsa, basswood, leather and fabrics. The kit is designed to fully comply with high powered Class 4 laser regulations.
Tersa Planer Knives – The Original
TersaKnives is the Canadian source for all your Tersa planer knives. Tersa knives are set automatically and accurately by special gibs and centrifugal force – no screws are required. Blade changeover takes only seconds. TersaKnives carries knives in HSS, M+, Carbide and Chrome Steel in 40mm to 810mm lengths, custom lengths available. You get the best prices plus same or next day shipping, and free shipping on orders over $250.
CNC Shark II
The Shark II boasts a heavy duty gantry reinforced with plate aluminum and a rigid interlocking 16″ by 36″ aluminum table. It has anti-backlash, wear-compensated high precision lead screws on all 3 axis and is built to handle either large 2-1/4HP routers or the new water-cooled spindle from Next Wave Automation (router motors and spindle are sold separately). Adjustable bearings give greater stability during heavy cutting. Upload designs via a USB flash drive. The Shark II includes VCarve Desktop V9 Design software, Vector Art 3D Sampler Pack, and CNC Shark control software.
Worx Pegasus Worktable and Sawhorse
The Pegasus WX051 is a versatile, space-saving worktable that quickly and easily converts into a sawhorse that supports up to 1,000 pounds. The compact, lightweight design allows for easy transportation and storage. It has a 31″ x 25″ tabletop that supports up to 300 lbs and features integrated quick clamps and slots for four clamp dogs that provides secure clamping for materials. A lower storage shelf holds tools and materials, and includes a place to attach a power strip. Can be interlocked it with another Pegasus to get an expanded work surface.
Worx 6-1/2 Circular Saw with ExacTrack
With an ExacTrack WX530L circular saw you can make precise rip, crosscut, and plunge cuts in sheet goods and solid stock. Simply clamp an edge guide, or any straight length of ply or solid wood, along your cut line, and the innovative ExacTrack feature will keep the saw blade flush against the edge guide for a precise, perfect cut. In standard mode the saw makes regular 90° or bevel cuts up to 50°. Cut stock up to 2-5/32″ thick at 90° and 1-17/32″ at 45°. At just under 6 pounds, the WX530L is easy to use.
6″ Jointer
This heavy duty jointer is available with either a 3-HSS straight knife cutter head (model 30-200S1) or with 16 double-sided replaceable cutter head knives (model 30-200H S1). The 1HP motor delivers a cutterhead speed of 5,000 RPM. The 55-3/4″ long cast iron bed and enclosed steel base provide excellent stability and minimal vibration. The large cast iron fence has angle stops at 45°, 0°, and -45°. The jointer also features a lockable magnetic switch, large hand wheels with retractable handles, and a 4″ dust port. Both models include a cutterhead guard and two push blocks.
20″ Planer with Helical Cutter Head
Equipped with a 5HP 220V motor and a 58-knife helical cutterhead, the 35-410HS3 planer offers superior planing on stock up to 20″ wide, making it ideal for professional shops and avid hobbyist woodworkers. You can select between two cutterhead speeds – 16 feet/minute for quick dimensioning of stock, and 20 feet/minute for a smoother finish. The planer handles stock as short as 6-3/4″ long, and between 1/4″ and 8″ thick. The heavy duty cast iron frame, steel integrated mobile base, and heavy 55″ long cast iron bed weigh in at 926 pounds, delivering exceptional stability.
Select Cast Iron Router Table
The 45-135 is a precision routing table that includes a precision machined 11-3/4″ by 9-1/4″ router lift that accepts most large 3 and 3-1/2HP routers. The router lift comes with four insert plates. This unit features a sturdy 24″ by 32″ cast iron table atop a rigid steel stand that absorbs vibrations and provides greater stability. The router table includes a 36″ aluminum adjustable parallel guide with dust collection outlet, transparent guard and flip stop. A dust collection box with 4″ deep utility drawer mounted under the table top is connected to the 4” outlet on the guide.
1-1/2HP Portable Dust Collector
The economically priced 80-150S2B dust collector features a totally enclosed fan cooled motor rated for continuous use. The motor delivers an airflow capacity of 1,250 CFM at an 80 decibel noise level. The collector is mounted on four swivel casters for easy movement around the shop from one machine to another. The 12-3/4″ precision balanced impeller is designed for smooth operation and minimal noise. The unit features a quick-release bottom bag clamp with metal straps and an extra thick, transparent, recyclable 42 gallon dust bag.
26″ Double Drum Sander
The 3HP 220V 50-725S3 is an industrial grade sanding machine that handles stock from 1/4″ to 12″ thick and as short as 5″ – in a single pass. The motor drives the 5″ drum at 1,550 RPM, while the 1/6HP feed belt motor provides variable feed speeds from 3 to 20 feet/minute. Aligning the drum to the bed is quick and easy, as is rising and lowering the drum head to set the amount of stock removal. Dust control is maximized by means of two 4″ dust ports atop the sander.
10″ Industrial Table Saw
The model 10-500S3 table saw features a robust 3HP 220V motor. A cast iron 29″ by 42″ main table sits on a heavy duty steel base, while a 36″ table extension provides a full 78″ work surface. The Biesemeyer style rip fence glides smoothly, providing a 50″ rip capacity to the right of the blade, and a 14″ rip capacity to the left side. You get a full 3″ cut capacity at 90° and 2-1/8″ at 45°. This saw also features 2 Internal stops for quick 45° and 90° blade adjustment, shaft button lock, blade guard, anti-kickback pawls and both a standard and European-style riving knife.
Award Winning BESSEY GearKlamp
The GearKlamp from BESSEY is a first of its kind in the world. It easily reaches places that were previously difficult or impossible to access. This unique clamp is all made possible by a patent pending mechanism that allows the separation of the spindle from the handle and, where the handle is positioned around the rail. This innovative design offers a surprisingly comfortable clamping position and permits applications in places where traditional clamps would not be practical. Available in 6″, 12″, 18″ and 24″ clamping capacities.
Every Wood Shop Needs a Great Knife
Flexcut knives are precision made for maximum performance. Their high-carbon steel blades have durable points, hold an edge extremely well and are easily maintained by simple stropping. Each knife is expertly hand-sharpened and tested before shipping, so it’s ready to use right out of the package. Comfortable, curved ash handles allow for long periods of carving without hand fatigue. A wide range of knives are available to handle every task from roughing in to fine detail carving. Flexcut knives are versatile, well-engineered tools, 100% North American made, assembled and sourced.
FEIN Cordless MultiMaster
For the woodworker, tradesperson, renovator, or DIY enthusiast, the German-made FEIN 18V cordless MultiMaster is the ultimate multi-power tool. A self-supporting motor with vibration decoupling provides outstanding vibration and noise reduction, while a high torque motor delivers performance identical to the corded version. The unique Starlock snap-fit mounting system, in conjunction with the QuickIN tool-free clamp, enables you to change accessories in less than 3 seconds. FEIN offers the most extensive range of accessories on the market, which opens up an exceptional range of applications.
E-Cut Carbide Pro
FEIN’s new Titanium Nitride (TiN) coated hard metal plunge cut saw blade has outstanding wear resistance, providing 100% higher service life compared to non-coated hard metal saw blades and 30 times longer lifespan compared to HSS saw blades. It’s the perfect choice for hard materials such as ferrous metals, stainless steel or copper pipes. It can be used for tempered screws (Spax) and high-strength machine screws, as well as abrasive materials like brick, masonry and cement fiber slabs, not to mention laminate, CFRP and GFRP. The E-Cut is compatible with Starlock mounting systems.
BORA WTX Clamp Edge Saw Guide
The secret to getting straight, clean rip and cross cuts with your circular saw is to use a Hi-ATB blade and the Bora 50” WTX Clamp Edge Saw Guide. The WTX is available with either a 50″ track (543056K) or a 100″ track (543106K). Each kit consists of a heavy-gauge, extruded aluminum clamp edge guide track and a 9″ x 15″ Bora Saw Plate. The edge guide is made of heavy grade aluminum for a lifetime of use – the 50″ edge guide is expandable for up to 8′ of cutting capacity with optional accessories. An adjustable clamp slides easily up and down the edge guide to securely fit material to be cut, while a locking handle grabs work surfaces for a secure edge that won’t budge. The Saw Plate has three connection points to attach your circular saw – the plate is compatible with most left or right handed 7-1/4″ circular saws currently on the market. You can also purchase optional plates to attach a Jig Saw and a Router to the WTX edge guide bar, ensuring precisely guided sawing and routing. The WTX comes with a lifetime warranty and is available at Home Depot stores across Canada.
Dremel Ultra-Saw
The US40 is a mini circular saw designed for users who want a versatile cutting tool simple enough to be controlled with one hand. With a 7.5 Amp motor and a durable drive train, the Ultra-Saw has more power for making long cuts. A metal foot and guard resists the heat generated by heavy-duty jobs like grinding and cutting metal. Large, 3-1/2″ and 4″ cutting wheels give this saw fast cutting speeds and improved performance in a wide variety of materials. Plus, with the various accessories from Dremel you can perform surface preparation tasks like removing paint, rust and thin-set mortar.
Dremel High Performance Variable Speed Rotary Tool
The 4300 features tool-less and collet-less accessory changes and a three-jaw chuck. The chuck accepts all Dremel accessory shank sizes for fast and convenient accessory changes without ever using a wrench. An all new Pivot Light enables you to direct illumination where you want it. The 1.8 Amp motor delivers built-in variable speed 5,000 to 35,000 RPM and electronic feedback circuitry. The slim, ergonomic body design provides a comfortable 360-degree grip zone no matter how you hold it for extended ease of use. The completely redesigned airflow system lets the 4300 run cool, quiet, and smooth so completing projects are more enjoyable than ever.
Dremel Multi-Max Oscillating Tool
The MM50 oscillating tool features a unique tool-less mechanism that is designed for quick and secure accessory change-over. A powerful 5.0 Amp motor delivers variable speeds from 10,000 to 21,000 OPM (orbits per minute) for optimal performance with a variety of materials. The MM50 weighs only 3 pounds, and coupled with an innovative angled body design, and compact and durable front end, it enables you to get into tight spaces with less vibration than comparable tools, affording more control over the tool, particularly for precision work.
Dremel 3D Printer
The 3D45 is one of the most reliable and easy-to-use 3D printers on the market, enabling you to use expanded filament types such as nylon and eco-ABS. It also has filament detection via RFID that enables the printer to automatically recognize and change settings for optimized printing. The fully enclosed build chamber minimizes warping from temperature fluctuations, while a filament recognition system automatically adjusts heat settings to achieve the optimum conditions for 3D printing. With additional new features like a heated bed and an integrated camera, you can take 3D printing to the next level.
Dremel 4V Cordless Rotary Tool
The 7760-N/10 cordless rotary tool, equipped with a 2.0 Ah lithium-ion battery, can be used with most Dremel accessories and a selection of attachments. It features an EZ Twist nosecap with integrated wrench for fast accessory changes, a shaft lock button, USB charging port, and 10 accessories with a plastic storage case. Its lightweight design and soft grip material provides maximum portability, comfort, and control.
Dremel DigiLab Laser Cutter
The LC40-01 is an easy-to-use laser cutter capable of cutting, scoring, and engraving on wood, stone, glass, leather, paper, rubber, plastic, vinyl, and other non-metal materials. It features an industry standard 40 watt glass laser tube with easy connect linkage for fast tube replacement. A built-in camera lets you scan your drawings or photos into the laser software for easy cutting and engraving, while a large, 7″ LCD touch screen lets you effortlessly manage and run jobs. Built-in smart sensors detect potentially hazardous situations and assist you with troubleshooting. Includes a full 1 year warranty.
Smart Logger Temperature & Humidity Sensor
The Smart Logger is a small, lightweight, easily portable and highly accurate monitoring device that tracks ambient temperature and humidity conditions when you are away from the job site or workshop. It can also be utilized during the wood acclimation process and the storage of wood. The Smart Logger is capable of storing up to 12,000 pieces of data over a period of up to 300 days. It incorporates the latest Bluetooth technology and works in tandem with the Smart Logger app, which can be downloaded for free at the Apple Store or Google Play. The app connects the Smart Logger to your mobile device enabling you to transmit and record data, and even send reports via email.
Orion 950 Smart Pinless Wood Moisture Meter
The Orion 950 Smart Moisture Meter is the pinnacle achievement of the Orion line, designed for professional wood flooring installers/inspectors, quality control managers, restoration professionals and serious woodworkers who need superior accuracy, versatility, and ruggedness in their critical moisture measurement instruments. The Orion 950 continues Wagner’s 50-plus year tradition of providing accurate, dependable, non-damaging pinless moisture measurement technology, measuring IN the wood, not just ON the wood, and backed by Wagner’s industry-leading 7-year warranty. The Orion 950 interacts through Bluetooth technology with a free mobile app for your Android or Apple smart device. It provides readings at 1/4″ and 3/4″ depth modes to measure the moisture content of thin samples such as wood floors or deeper into thick wood samples. You can quickly obtain the ambient temperature and relative humidity measurements of any room with its built-in sensor, and the Orion 950 calculates and displays the current dew point when needed. It will also calculate if a wood specimen is at the critical threshold where it has reached its equilibrium with the environment and will no longer gain or lose moisture.
14″ Deluxe Bandsaw with Smart Motor DVR Control
The Rikon 10-326DVR bandsaw is equipped with a 1-3/4HP Digital Variable Reluctance (DVR) motor that delivers infinitely variable speed and power with continuous torque. DVR motors provide improved energy efficiency and quiet, vibration-free operation. With an easy-to-read screen and DVR controller, this technology adds much-needed features to the bandsaw. Features include a 13″ resaw capacity, blade speed from 100 RPM to 2,375 RPM (4,400 SFPM), -7° to 45° table tilt, and a 6” tall by 18-3/4″ long rigid aluminum rip fence with re-saw bar. Comes with a 5 year warranty (2 years on the motor).
Limited Edition 30th Anniversary G3 Chuck Bundle
This limited edition 30th Anniversary Bundle (48246) includes a 1″ x 8TPI Thread G3 Chuck designed exclusively for the NOVA Comet II Midi Lathe. The G3 Chuck has an anti-release spindle lock that ensures the chuck will stay securely mounted on the lathe during forward and reverse turning applications, and a reversible feature. The bundle also includes a JS100N 100mm/4″ Jaws, JS50mm/2″ Jaws, JSPIN Pin Jaws, T-Handle Chuck Key, Woodworm Screw, and fastenings in a sturdy storage and carry case. Includes a 6-year full replacement warranty.
DEWALT ToughTrack Woodcutting Circular Saw Blades
These blades feature an innovative new tooth design, reduced vibration, high-density carbide teeth, and a reinforced shoulder, making them durable options for long periods of use on the jobsite. Key to the new blades is the exclusive (patent-pending) ToughTrack technology, a tooth design that is engineered to deliver straight, accurate cuts over the life of the blade. The blades’ ATB+R tooth grind helps clear debris from the cutting channel, allowing for tracking and straight, smooth cuts. They are available in 6-1/2″, 7-1/4″ and 8-1/4″ sizes in 18, 24, 40 and 60-tooth formats.
Magnum Industrial 13″ Helical Head Planer
With 26 double-sided long-lasting carbide inserts and a precise helical cutterhead, the versatile 31-160 planer excels in short-run applications with either hard or soft wood. It features a 15 Amp motor that delivers a 10,000 RPM cutterhead speed at a feed speed of 26 FPM. Its redesigned infeed and outfeed tables fold up for easy storage and feature four adjustable support posts to minimize snipe. You can plane stock as short as 5″ in length and up to 6″ thick. This portable planer is ideal for small shops and jobsite applications where a high-quality finish is critical.
Magnum Industrial 1 HP Two-Bag Dust Collector
The fully enclosed continuous-duty 1HP motor on the 11-100 mobile dust collector provides an air flow capacity of 750 CFM, yet only draws 7 Amps of power. It has a washable 2 micron filter bag and a 20 gallon clear plastic bottom dust collection bag. Quick-release metal straps secure both bags and allow quick bag changes. Built-in swivel-style casters deliver excellent mobility, allowing you to position the 11-100 close to machinery to collect dust at its source. It’s the perfect dust collector for professionals and serious hobbyists working in smaller shops.
Magnum Industrial 8″ Benchtop Jointer
Accurate and durable, the 81-180 benchtop jointer combines the cutting capacity of a larger machine with the convenience of a benchtop model. A 1HP motor delivers a cutterhead speed of 12,000 RPM while 16 double-sided carbide inserts provide a smooth, clean surface on just about any wood. Features include a 30″ long table, 20″ fence length, and 4″ dust outlet with a 2″ reducer should you want to use a dust extractor with the jointer. The 81-180 is perfect for light-duty jointing and straightening twisted boards around your home workshop.
Magnum Industrial Combination Belt and Disc Sander
Built with sealed ball bearings and no bushings, the 16-210 belt and disc sander features a double-insulated direct-drive 1/2HP motor for continuous use applications. It accepts 1″ x 42″ belts, 2″ x 42″ belts and 8″ discs. An improved belt tracking mechanism provides controlled, accurate sanding while a quick-release belt tensioner makes changing belts easy. Both cast-iron tables tilt and lock 0° to 45° for accurate angle sanding. A dust collection port with separate dust boot for disc and belt allows efficient dust control. For sanding wood or sharpening tools and knives, the 16-210 is up to the task.
Magnum Industrial 10″ 2HP Cabinet Saw
A true left-tilt cabinet saw with base-mounted trunnions for vibration free operation and easy fine-tuning, the 51-100 10″ cabinet saw features a precision self-aligning T-fence and a powerful fully enclosed 2HP motor that operates on either 220 or 110 volts (pre-wired for 220 volts). The 51-100 comes equipped with a removable riving knife and see-thru guard with anti-kickback features. You get a maximum cutting depth of 3″ at 90° and 2-1/4″ at 45°. This saw is ideal for both professional cabinet shops and serious hobbyists.
Magnum Industrial Deluxe 14″ Wood Band Saw
Whether you are buying your first band saw or looking to upgrade, the 91-350 offers performance and versatility at an outstanding price. Designed to meet the needs of small to medium shops, its dual voltage 1HP motor, pre-wired for 120V, delivers dual blade speeds of 1,800 and 3,000 FPM. Features include a 6″ resaw capacity and 13″ cutting width, ball bearing guides, heavy cast-iron dynamically balanced wheels and cast-iron frame, a 16″ square table that tilts 10° to the left and 45° to the right, a deluxe fence system, and a 4″ dust collection outlet.
Diablo SandNet Discs
SandNet discs provide 10x longer life versus standard sanding discs. Each disc features a clog-reducing net design coated in premium aluminum oxide grit for fast material removal while reducing material build-up. You can clean and reuse a disc multiple times by simply shaking, vacuuming, or rinsing the disc with water to remove any dust build-up. They can be used for sanding wood, metal, plastics and solid surfaces. These premium 5″ discs are available in 10 and 40 packs in 8 sizes from 60- to 600-grit. Each pack includes a free connection pad (a $5 value) for easy attachment to tool.
Freud 10″ Next Generation General Purpose Blade
Freud’s Next Generation blades with their radical new Fusion Trio Tooth Design are the most technologically advanced general purpose blades on the market. The design combines a special grind for the top, sides, and face of each tooth that includes a 30° Hi-ATB, a double grind design, and an Axial Shear Face Grind to produce the ultimate polished finish in ripping and crosscutting applications with minimal resistance. These blades deliver flawless cuts in laminates, melamine, veneered plywoods, hardwoods, softwoods, and thick stock lumber.
EAB Exchangeable Razor Thin Circular Saw Blades
EAB Razor Thin blades, with C2 carbide teeth, deliver fast, effortless cuts, leaving a kerf of only 1.56mm wide. They are ideal for cordless saws as they provide longer battery run time than standard blades. An integrated anti-kickback design makes for safe use. These value priced blades are available in 6-1/2″ and 7-1/4″ sizes and come with an Exchange Credit. When the blade is dull or damaged, simply return it to your dealer, who will apply the Exchange Credit towards your next EAB purchase.
DAP WoodPro Wood Fillers
These new DAP wood fillers are made from a high quality, latex-based formula that creates a surface and body that looks and acts like real wood. The thick, knife-grade formula can be moulded and sculpted making it ideal for corners, vertical and unsupported surfaces. Use them to repair cracks, gouges, holes and other surface defects on furniture, woodwork, moulding, cabinets, panelling, plywood, windows, doors and painted surfaces. This easy-to-use filler is low in odour and cleans up with water. WoodPro has a natural tone, while WoodPro-X goes on pink and dries natural.
