Top 10 workbench accessories
Workbenches are the focal point of many workshops, but they don’t work alone. Accessories make a workbench more efficient, useful, accurate and enjoyable.
1. Face Vise – Maybe it’s assumed that a workbench will have a vise on it, but I’ve added it just in case yours doesn’t. Easily the most important accessory to a workbench, a vise will help out in many ways. I added two face vises to the front of my bench, but some prefer just one. This approach will leave room for a tail vise, typically at the right end of the bench.
2. Tail Vise – A tail vise is positioned at the end of a bench. It’s very similar to a face vise, but it holds a workpiece in a slightly different way. It’s also regularly used to secure a workpiece on top of a bench, with the use of bench dogs.
3. Bench Dog – A bench dog can be store-bought or shop-made. Usually round, but sometimes rectangular, a bench dog can be positioned in any one of the holes in the top of your bench to offer a surface to clamp a workpiece against. A second bench dog can be used in a vise to provide the clamping power.
4. Handsaw Hook – A bench hook will help you make 90° and 45° cuts, not to mention any other cuts you’d like to make a hook for. These are very simple bench accessories and are generally shop-made. A base, with a fence attached to the top of the base, along with a block on the underside to help secure the base while cutting, is all you really need. I secure this jig in my face vise, though other hooks will reference off the front edge of your bench.
5. Planing Stop – Purchase or made, a planing stop can be inserted into the bench dog holes on your bench and used to give you a stop to plane against. Once you have one you’ll likely realize there are many tasks these stops can help you out with.
6. Veritas Inset Vise – This type of vise can be added to any bench that’s at least 1-1/4″ thick. It works with existing bench dog holes to secure workpieces on top of your benchtop. I installed a Veritas inset vise on my bench and I strongly recommend one.
7. Moxon Vise – A moxon vise will assist you when you’re using hand tools to work with smaller workpieces. It will allow you to bring the workpiece to a more helpful height and do a great job at securing it for cutting, planing, paring and so on.
8. Adjustable Light – A bench is just about useless with­out proper lighting. Even if you have your bench right in front of a window, an adjustable light will allow you to direct light towards where you’re working even if it’s dark outside.
9. V-Groove Holder Jig – This jig will help secure round or odd-shaped workpieces so they can be worked on. I also use this jig to hold work that I’m chamfering. I secure this jig in my face vise, but there’s nothing wrong with making one that can be inserted into a couple of bench dog holes or be secured with a tail vise.
10. Belt Sanding Stop for Vise – Although I mainly use this stop for belt sanding workpieces, it also has other uses. It’s simple to make by fixing a block to the underside of the base. The block gets secured in place with a face vise and the base can be used as a stop.
Rob Brown - [email protected]
More Top 10 Lists
Top 10 essential power tools for the woodworker
These 10 power tools will make your DIY...
Top 10 DIY hand tools
Make your home maintenance and improvement jobs easier...
Top 10 power and hand tools for the new woodworker
After a few of the obvious basics (tape...
